この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will disassemble the device the most concise way possible to allow you to replace the Tape Player Cover.
必要な工具と部品
With a Phillips #0 screwdriver, remove the eight 9.5mm screws attached to the left and right panels of the device.
Use thumbs to push the casing forward as indicated.
Note the position of the tabs in these pictures. Once the casing has slid forward, it should come loose. Place it aside.
もう少しです!
終わりに
