メインコンテンツにスキップ
Panasonic PV-GS9 microphone replacement
必要な工具と部品
  1. Panasonic PV-GS9 microphone replacement, Microphone Replacement: 手順 1、 3の画像 1 Panasonic PV-GS9 microphone replacement, Microphone Replacement: 手順 1、 3の画像 2 Panasonic PV-GS9 microphone replacement, Microphone Replacement: 手順 1、 3の画像 3
    • Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
  2. Panasonic PV-GS9 microphone replacement: 手順 2、 2の画像 1 Panasonic PV-GS9 microphone replacement: 手順 2、 2の画像 2
    • Open the tape compartment.
    • Then flip the camcorder and locate two 4.5mm screws that are horizontal from each other and about 2 inches apart using a #00 Phillips screwdriver.
  3. Panasonic PV-GS9 microphone replacement: 手順 3、 3の画像 1 Panasonic PV-GS9 microphone replacement: 手順 3、 3の画像 2 Panasonic PV-GS9 microphone replacement: 手順 3、 3の画像 3
    • Use the blue plastic opening tool to remove the gray trim piece by prying it from top of the camcorder.
    • Be gentle when removing the trim piece. The plastic parts are fragile and can break easily.
  4. Panasonic PV-GS9 microphone replacement: 手順 4、 1の画像 1
    • Rotate the camcorder so that the eye piece is facing you.
    • Remove the four black 4.5mm screws, sitting behind the battery.
    • Remove the 5th screw to the right of the battery dock.
    • Remove the battery by gently pulling away from the camcorder.
    • Be careful and place screws together so you don't lose any.
  5. Panasonic PV-GS9 microphone replacement: 手順 5、 2の画像 1 Panasonic PV-GS9 microphone replacement: 手順 5、 2の画像 2
    • Rotate the camcorder so that the tape compartment is facing you.
    • Remove the single 4.5mm black screw above the hook for the hand strap.
    • Undoing the strap on one end may help.
    • Rotate the camcorder so that the lens is facing you.
    • Remove the single 4.5mm black screw from the front panel.
  6. Panasonic PV-GS9 microphone replacement: 手順 6、 2の画像 1 Panasonic PV-GS9 microphone replacement: 手順 6、 2の画像 2
    • Rotate the camcorder so that the bottom is facing towards you.
    • Remove the single remaining 4.5mm black screw from the bottom.
    • Remove the four silver 4.5mm screws from the body.
  7. Panasonic PV-GS9 microphone replacement: 手順 7、 1の画像 1
    • Open the LCD screen on the side of the camcorder.
    • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
  8. Panasonic PV-GS9 microphone replacement: 手順 8、 2の画像 1 Panasonic PV-GS9 microphone replacement: 手順 8、 2の画像 2
    • Carefully remove the front cover from the body of the camcorder.
    • This should come apart with relative ease, however a plastic opening tool may help remove the panel.
    • There is a ribbon cable attached to the front panel and the camcorder body, DO NOT pull that off when you remove this panel.
  9. Panasonic PV-GS9 microphone replacement: 手順 9、 2の画像 1 Panasonic PV-GS9 microphone replacement: 手順 9、 2の画像 2
    • Using your fingers, carefully pull the ribbon cable away from the logic board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
13人の作成者と共同で作成されました。
Trevor Johnson
メンバー登録日: 04/18/10
31 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 7-9, Maness Spring 2010 Cal Poly, Team 7-9, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S7G9
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 2,701
