メインコンテンツにスキップ
Panasonic Lumx DMC-ZS19 Capture Button Replacement
必要な工具と部品
  1. Panasonic Lumx DMC-ZS19 Capture Button Replacement, LCD Screen: 手順 1、 3の画像 1 Panasonic Lumx DMC-ZS19 Capture Button Replacement, LCD Screen: 手順 1、 3の画像 2 Panasonic Lumx DMC-ZS19 Capture Button Replacement, LCD Screen: 手順 1、 3の画像 3
    • Locate the pair (2) of screws on each side of the camera and remove them. Then locate the pair (2) of screws on the bottom of the camera, located on each side of the tripod screw-in area, and remove them.
  2. Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 2、 1の画像 1
    • Using the plastic prying tool, remove the cover of the camera that is on the same side as your LCD screen. This cover should come off relatively easily, and will expose the motherboard that the screen is connected to.
  3. Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 3、 1の画像 1
    • Disconnect the motherboard that the LCD screen is connected to from the main motherboard.
  4. Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 4、 1の画像 1
    • Using your hand, follow the two data-strips that connect the LCD screen to the motherboard and unclip them. Once the data-strips are unclipped, remove them from the motherboard and the screen will be free.
  5. Panasonic Lumx DMC-ZS19 Capture Button Replacement, Lens: 手順 5、 2の画像 1 Panasonic Lumx DMC-ZS19 Capture Button Replacement, Lens: 手順 5、 2の画像 2
    • After the screen has been removed, the main motherboard is directly underneath it. There is a bronze, metal separation piece that separates the main motherboard from the one connected to the lens. This metal piece is held in with 3 screws. Remove these 3 screws and the metal piece will be free.
  6. Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 6、 1の画像 1
    • Once the bronze metal plate is removed, the main motherboard will be exposed. There is a plastic riser (it looks like a lowercase "b" on the right side of the camera) that separates the metal plate from the motherboard. Remove this plastic riser.
  7. Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 7、 3の画像 1 Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 7、 3の画像 2 Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 7、 3の画像 3
    • Once the plastic riser is removed, it is time to remove the lens. To do this, simply follow the data strips (2) that connect the lens to the main motherboard and unclip them by turning the black bar into a position that is perpendicular to the motherboard. Once these clips are open, the data strips and the lens should simply slide out.
  8. Panasonic Lumx DMC-ZS19 Capture Button Replacement, Motherboard: 手順 8、 1の画像 1
    • After the lens has been removed, there is only one screw that holds the main motherboard in place. Remove this screw, located on the right side of the motherboard, and remove it.
  9. Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 9、 3の画像 1 Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 9、 3の画像 2 Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 9、 3の画像 3
    • Once the screw has been removed, the motherboard should pop right out. If you're having difficulties, use the plastic prying tool.
  10. Panasonic Lumx DMC-ZS19 Capture Button Replacement, Capture Button: 手順 10、 3の画像 1 Panasonic Lumx DMC-ZS19 Capture Button Replacement, Capture Button: 手順 10、 3の画像 2 Panasonic Lumx DMC-ZS19 Capture Button Replacement, Capture Button: 手順 10、 3の画像 3
    • Once the motherboard has been removed, flip the camera over and remove the front panel.
  11. Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 11、 3の画像 1 Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 11、 3の画像 2 Panasonic Lumx DMC-ZS19 Capture Button Replacement: 手順 11、 3の画像 3
    • After the front panel is removed, the buttons are connected by a simple string of clips. To remove the buttons, find the clip on the back and the two on the front that are connecting the buttons to the shell of the camera. Remove these clips and pull the buttons up from the back at an angle towards the front to remove them.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Patrick Thoennissen
メンバー登録日: 09/14/15
494 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 14-1, Meier Fall 2015 USF Tampa, Team 14-1, Meier Fall 2015人のメンバー
USFT-MEIER-F15S14G1
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 347
