メインコンテンツにスキップ
Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement, Battery Compartment Cover: 手順 1、 1の画像 1
    • Remove the bottom Phillips head screws on the camera to take off the outer plastic housing. Be careful when pulling the piece off; if something seems stuck, double check to make sure every screw on the bottom was removed.
  2. Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: 手順 2、 3の画像 1 Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: 手順 2、 3の画像 2 Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: 手順 2、 3の画像 3
    • Once the screws have been removed, slowly and carefully take the top half of the housing off the camera.
    • Flip the camera over, and carefully lift the screen while still making sure it's fully attached to the camera.
  3. Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: 手順 3、 2の画像 2
    • With the screen flipped over, you now have access to the metal plate under it. Using the same Phillips screwdriver, remove the metal plate. Doing this will give you access to the push pin holding the cover in place.
    • Use a small needle, pin, or needle nose pliers to slide the pin right out. Be sure to keep the pin and spring in a safe spot to prevent loss.
  4. Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: 手順 4、 1の画像 1
    • Once you have replaced the the pin and spring with the new cover, be sure to check that the spring action still functions. Also check that the battery sits properly in the compartment and the cover locks and fits properly.
    • If this works, then you're done! When reassembling the camera, be sure to make sure that all of the screws go tightly back in place in the same order that they were taken out.
終わりに
To reassemble your device, follow these instructions in reverse order. Be sure to check that the spring action still functions and that the battery fits while still closing and locking properly.
作成者
6人の作成者と共同で作成されました。
David Garza
メンバー登録日: 03/03/15
141 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team 13-13, Blackburne Spring 2015 Sam Houston State, Team 13-13, Blackburne Spring 2015人のメンバー
SHSU-BLACKBURNE-S15S13G13
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 16
過去 30 日: 29
今までの合計 2,209
