はじめに
If your Panasonic Lumix DMC-ZS40 wont turn on and your battery is fully charged then replacing the motherboard is what you'll need to do in order to get your camera back up and running.
必要な工具と部品
Find the battery/memory card door on the bottom right of the camera.
Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
Unscrew the five 3mm screws located around the sides of the camera using a PH000 bit or Phillips 000 Screwdriver.
Disconnect the control dial from the motherboard. Locate the ZIF connector for the control dial. Use tweezers or screwdrivers to lift up on the retaining flap to remove the ribbon cable.
ある他の人がこのガイドを完成しました。
