メインコンテンツにスキップ
Panasonic Lumix DMC-ZS40 Camera Sensor Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Battery: 手順 1、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Battery: 手順 1、 2の画像 2
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 2、 1の画像 1
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 3、 2の画像 2
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 手順 4、 3の画像 1 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 手順 4、 3の画像 2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: 手順 4、 3の画像 3
    • Unscrew these five 3mm screws located around the sides of the camera using a screw driver with a PH000 bit head.
  5. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 5、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 5、 2の画像 2
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 6、 1の画像 1
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 7、 3の画像 1 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 7、 3の画像 2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 7、 3の画像 3
    • Place the LCD screen to the side while you remove the plate cover. The LCD has already been removed in this picture. It is not necessary to remove the LCD screen or the control dial for this guide.
    • Remove these four 4mm screws and the 3mm screw on the top of the plate cover and on the side of the camera using a PH000 bit head. Once the screws are removed, the plate cover should lift right up.
    • Keep track of the different screw lengths and do not mix them up.
  8. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    • Remove the ribbon cable connecting the sensor to the motherboard. Use tweezers or a screw driver to lift up on the retaining flap of the ZIF connector to remove the cable.
  9. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 9、 1の画像 1
    • Using the T3 Phillips Screwdriver, unscrew the three Torx T3 2.5mm screws holding the sensor down.
  10. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 10、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: 手順 10、 2の画像 2
    • Gently lift the sensor off of the springs.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Dean Favetta
メンバー登録日: 02/14/17
340 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 20-3, Remmell Spring 2017 USF Tampa, Team 20-3, Remmell Spring 2017人のメンバー
USFT-REMMELL-S17S20G3
3 メンバー
10のガイドは作成済み
1件のガイドコメント
After the CCD is replaced, how do you adjust the 3 torx screws, so the ccd is in alignment? After the replacement the right side of my pictures are out of focus.
resufix888 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 1,089
