はじめに
You may need to replace or clean your Panasonic Lumix DMC-ZS40 Camera Sensor if splotches/dirt are appearing in your photos, or if the LCD screen remains black when attempting to take photos.
必要な工具と部品
Find the battery/memory card door on the bottom right of the camera.
Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
Unscrew these five 3mm screws located around the sides of the camera using a screw driver with a PH000 bit head.
ある他の人がこのガイドを完成しました。
コメント 1 件
After the CCD is replaced, how do you adjust the 3 torx screws, so the ccd is in alignment? After the replacement the right side of my pictures are out of focus.
resufix888 - 返信
