メインコンテンツにスキップ
Panasonic Lumix DMC-ZS40 Camera Lens Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Battery: 手順 1、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Battery: 手順 1、 2の画像 2
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 2、 1の画像 1
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 3、 2の画像 2
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, LCD Screen: 手順 4、 3の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, LCD Screen: 手順 4、 3の画像 2 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, LCD Screen: 手順 4、 3の画像 3
    • Unscrew the five 3mm screws located around the sides of the camera using a PH000 bit or Phillips 000 Screwdriver.
  5. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 5、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 5、 2の画像 2
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 6、 1の画像 1
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 7、 3の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 7、 3の画像 2 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 7、 3の画像 3
    • Turn the LCD screen over to the side exposing the connection to the motherboard.
    • Remove the display data cable connecting the LCD screen to the motherboard. Using tweezers, pry up the black retaining flap then gently pull the display data cable free.
    • Be careful when handling any display data cables in the camera as they are prone to tearing.
    • To close for reassembly, slide the display data cable back into the ZIF connector and close the retaining flap.
  8. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Motherboard: 手順 8、 1の画像 1
    • Disconnect the control dial from the motherboard. Locate the ZIF connector for the control dial. Use tweezers or screwdrivers to lift up on the retaining flap to remove the ribbon cable.
    • The connector ribbons are prone to tearing so use care during removal.
  9. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 9、 1の画像 1
    • Pry the HDMI cover off the side of the camera.
    • No tools are required for this step.
  10. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 10、 3の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 10、 3の画像 2 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 10、 3の画像 3
    • Remove these four 4mm on the top of the plate cover and the 3mm screw on the side of the camera using a PH000 bit head. Once the screws are removed, the plate cover should lift right up.
    • Keep track of the different screw lengths and do not mix them up.
  11. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 11、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 11、 2の画像 2
    • Pry the black cover shielding the ZIF connectors off with your hand.
  12. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 12、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement: 手順 12、 2の画像 2
    • Disconnect these 6 ribbon cables from the motherboard. Use tweezers or a screw driver to lift up on the retaining flaps for each ZIF connector.
  13. Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Camera Lens: 手順 13、 2の画像 1 Panasonic Lumix DMC-ZS40 Camera Lens  Replacement, Camera Lens: 手順 13、 2の画像 2
    • Once the corresponding ribbon cables have been detached, the lens assembly can be lifted right up.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dean Favetta
メンバー登録日: 02/14/17
340 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 20-3, Remmell Spring 2017 USF Tampa, Team 20-3, Remmell Spring 2017人のメンバー
USFT-REMMELL-S17S20G3
3 メンバー
10のガイドは作成済み
コメント 1 件
My Lumix is a bit older and so did not follow exactly. But this was helpful enough to allow me to work through the lens issue. In doing some reading, often the lens doesn't need replacing, just a good cleaning or even to reset it in the housing which worked for me. One thing I would say is refrain from taking the plastic clamps off. They are hard to get off and usually snap due to how brittle they get. Instead, leave in place and be careful with the cable.
David Blitt - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 1,875
