メインコンテンツにスキップ
Panasonic Lumix DMC-ZS3 Lens Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: 手順 1、 3の画像 1 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: 手順 1、 3の画像 2 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: 手順 1、 3の画像 3
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 2、 2の画像 1 Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 2、 2の画像 2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 3、 2の画像 2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 4、 1の画像 1
    • Remove the two LCD board ribbon cables out of their sockets.
  5. Panasonic Lumix DMC-ZS3 Lens Replacement, Lens: 手順 5、 1の画像 1
    • Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 6、 3の画像 1 Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 6、 3の画像 2 Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 6、 3の画像 3
    • Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
    • The LCD ribbon cables connect the back cover to the rest of the unit.
    • Use the spudger to disconnect the LCD ribbons.
  7. Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 7、 3の画像 1 Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 7、 3の画像 2 Panasonic Lumix DMC-ZS3 Lens Replacement: 手順 7、 3の画像 3
    • Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
    • Excessive force may damage the camera. Be sure to lift the lens slowly and carefully to avoid damage to other parts.
    • Unlock lens mechanism located on the bottom of the device using your fingers.
終わりに
作成者
7人の作成者と共同で作成されました。
Kellen Ericson
メンバー登録日: 04/17/13
18 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S13G60
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 65
今までの合計 3,265
