メインコンテンツにスキップ
Panasonic Lumix DMC-ZS3 Back panel buttons Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back Cover: 手順 1、 3の画像 1 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back Cover: 手順 1、 3の画像 2 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back Cover: 手順 1、 3の画像 3
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: 手順 2、 2の画像 1 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: 手順 2、 2の画像 2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: 手順 3、 2の画像 2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: 手順 4、 1の画像 1
    • Remove the two LCD board ribbon cables out of their sockets.
  5. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back panel buttons: 手順 5、 3の画像 1 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back panel buttons: 手順 5、 3の画像 2 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back panel buttons: 手順 5、 3の画像 3
    • Use the flat end of the spudger to gently pry the buttons from the back panel.
    • Remove the buttons in three pieces, starting with the top left one, then moving to one next to it. Once this is finished remove the rest of the buttons.
    • The buttons are attached to the back cover using adhesive, and this may need to be reapplied to put them back on.
終わりに
作成者
4人の作成者と共同で作成されました。
Juan Pablo Quinonez Weston
メンバー登録日: 04/16/13
4 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 13-60, Johann Spring 2013 Cal Poly, Team 13-60, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S13G60
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 17
今までの合計 513
