メインコンテンツにスキップ
Panasonic Lumix DMC-TZ5 button board Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-TZ5 button board Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove the battery and memory card from the device.
  2. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 2、 1の画像 1
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 3、 1の画像 1
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 4、 1の画像 1
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 5、 1の画像 1
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 6、 2の画像 1 Panasonic Lumix DMC-TZ5 button board Replacement: 手順 6、 2の画像 2
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 7、 1の画像 1
    • Remove the back casing from the camera.
  8. Panasonic Lumix DMC-TZ5 button board Replacement, button board: 手順 8、 2の画像 1 Panasonic Lumix DMC-TZ5 button board Replacement, button board: 手順 8、 2の画像 2
    • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
    • Carefully remove the function switch cover. This unit snaps on and off.
  9. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 9、 1の画像 1
    • Carefully unsnap the front logic board from the rear logic board using a spudger.
  10. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 10、 2の画像 1 Panasonic Lumix DMC-TZ5 button board Replacement: 手順 10、 2の画像 2
    • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  11. Panasonic Lumix DMC-TZ5 button board Replacement: 手順 11、 3の画像 1 Panasonic Lumix DMC-TZ5 button board Replacement: 手順 11、 3の画像 2 Panasonic Lumix DMC-TZ5 button board Replacement: 手順 11、 3の画像 3
    • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
    • This leaves you with the logic board and the top connection panel separate and free from the camera
終わりに
作成者
4人の作成者と共同で作成されました。
Ben Canfield
メンバー登録日: 10/10/10
409 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 9-21, Regan Fall 2010 Cal Poly, Team 9-21, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S9G21
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 5,569
