はじめに
The flash unit is attached to the inner casing of the camera.
ツール
パーツ
パーツは指定されていません。
Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
Carefully remove the function switch cover. This unit snaps on and off.
Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
Use the spudger to unclip the top ribbon cable from the circuit board.
After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
First you must remove two 3.5mm blue screws near the hole of the lens that attach the inner casing.
Use a spudger to carefully lift the small clip located to the left of the unit.
Lift the flash unit out of the case.
2 の人々がこのガイドを完成させました。
2 件のコメント
Thank you for showing me how to fix my LUMIX TZ5 Camera.. I will do this as soon as I get the replacement flash.
Carlos
