メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This is the circuit board that the AV chord attaches to for transferring images.
パーツ
パーツは指定されていません。
  1. Remove the battery and memory card from the device.
    • Remove the battery and memory card from the device.
  2. Remove 4 screws from the right side of the camera.
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Remove the single 3.4mm screw on the left side of the camera.
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Remove 5 screws from the base of the camera.
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Slowly slide the back cover away from the device
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Remove the back casing from the camera.
    • Remove the back casing from the camera.
  8. Manta Driver Kit
    どんな修理にでも対応可能な112ビット
    Upgrade Your Toolbox
    Manta Driver Kit
  9. Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip. Carefully remove the function switch cover. This unit snaps on and off.
    • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
    • Carefully remove the function switch cover. This unit snaps on and off.
  10. Carefully unsnap the front logic board from the rear logic board using a spudger.
    • Carefully unsnap the front logic board from the rear logic board using a spudger.
  11. Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera. Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
    • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
  12. Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger. This leaves you with the logic board and the top connection panel separate and free from the camera This leaves you with the logic board and the top connection panel separate and free from the camera
    • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
    • This leaves you with the logic board and the top connection panel separate and free from the camera
  13. Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
    • Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
  14. Remove the 3 screws holding the lens assembly in place.
    • Remove the 3 screws holding the lens assembly in place.
    • The two screws on the left are 4.5mm with washers.
    • The single screw on the right is 4mm.
  15. Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
    • Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
  16. Remove the entire assembly out of the casing. The ribbons on the left and bottom of the assembly simply rest on the camera housing.
    • Remove the entire assembly out of the casing.
    • The ribbons on the left and bottom of the assembly simply rest on the camera housing.
  17. Use the spudger to unclip the top ribbon cable from the circuit board.
    • Use the spudger to unclip the top ribbon cable from the circuit board.
  18. Remove the single 2mm screw in the bottom right corner of the circuit board
    • Remove the single 2mm screw in the bottom right corner of the circuit board
  19. Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove. The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
    • Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
    • The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
  20. Take note of how the slots fit into the circuit board for easy replacement.
    • Take note of how the slots fit into the circuit board for easy replacement.
終わりに
2 の人々がこのガイドを完成させました。
Kevin Lufkin
メンバー登録日: 2010年10月11日
158 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 9-21, Regan Fall 2010 Cal Poly, Team 9-21, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S9G21
4 メンバー
7のガイドは作成済み
コメント1件
Where can I buy this part? Thanks!
Janx38 - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 7,889
