メインコンテンツにスキップ
Panasonic Lumix DMC-TZ35 LCD Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the back - 1: 手順 1、 2の画像 1 Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the back - 1: 手順 1、 2の画像 2
    • Remove 2 screws on the right hand side of the case.
    • Remove 2 screws on the left hand side of the case.
  2. Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the back - 2: 手順 2、 2の画像 1 Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the back - 2: 手順 2、 2の画像 2
    • Remove 2 screws on the bottom of the case, adjacent to the tripod mount. Note that these screws are slightly shorter than the previous ones and so should be kept separate.
    • Ease off the case back. You can help it off by inserting a spudger in the crack on all sides to ease it, especially either side of any points where it seems reluctant to come.
  3. Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the buttons board: 手順 3、 2の画像 1 Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the buttons board: 手順 3、 2の画像 2
    • Gently lift the locking bar on the LCD ribbon, then ease the ribbon out of the socket.
    • Lift the buttons board by inserting a spudger under the bottom right hand edge. This will detach it from a connector beneath.
  4. Panasonic Lumix DMC-TZ35 LCD Replacement, Removing the LCD: 手順 4、 1の画像 1
    • Release a clip on the left hand side of the LCD and hence lift the LCD out.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Philip Le Riche
メンバー登録日: 02/18/14
30,795 ポイント
47のガイドは作成済み
チーム
Restart Project Restart Project人のメンバー
Local Repair Groups
23 メンバー
661のガイドは作成済み
3 件のコメント
Theres a few missing steps. The old LCD screen will need removing from the container that holds it in and the new replacement LCD screen will need to be fitted inside it. Also, there are 2 connections on the LCD ribbon. One goes in as described. On the old screen carefully pull apart the 2nd connection between the screen and the camera. The new LCD screen will then need 2 dabs of solder on the 2nd connection between the new screens ribbon cable and the one within the camera. Its pretty straightforward but the screen will not work without both connectors fitted properly.
Anthony Todd - 返信
My camera was an Panasonic DMC-TZ70, but the difference was not big. The job was easy.
John Vonk - 返信
Same remark, mine is a Panasonic DMC-TZ37 (identical of DMC-TZ40 except the GPS) and it had a minor difference, LCD ribbon is on the back and can be easily removed after the release of the button board.
Rusterholtz - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 2,437
