メインコンテンツにスキップ
Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement, Pop-up Flash Spring Replacement: 手順 1、 1の画像 1
    • Orient the camera so that the display screen is facing you.
    • Press the flash button to reveal the camera's pop-up flash.
  2. Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement: 手順 2、 2の画像 1 Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement: 手順 2、 2の画像 2
    • Orient the camera so that the lens is facing you.
    • Remove two 2mm Phillips #0 screws on the sides of the flash.
  3. Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement: 手順 3、 2の画像 2
    • Remove the cover of the flash.
  4. Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement: 手順 4、 2の画像 1 Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement: 手順 4、 2の画像 2
    • Remove the 19mm pin by simply pushing from one side using the pointed end of a spudger.
    • Once the pin is removed, the bottom housing of the flash can be taken off from the camera by hand.
  5. Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement: 手順 5、 2の画像 1 Panasonic Lumix DMC-GX85 Pop-up Flash Spring Replacement: 手順 5、 2の画像 2
    • Similar to the previous step, remove the 19mm pin by pushing it from one side using the pointed end of a spudger.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jalen Peterson
メンバー登録日: 09/17/19
181 ポイント
1ガイドが承認済み
チーム
2 件のコメント
Hello,
sorry to bother you, but i would like to ask you for an expert opinion - help.
I had to replace the flash spring on my device / camera. After installation, the flash works as it should, but when closing the flash and turning off the camera, the camera tells me to insert the flash (then it turns off classically). I noticed that there was a small magnet in the flash, which I assume a function to confirm the closing of the flash door.
I would just like to ask where exactly to place it? I've already tried all the places where it should be stored, but I'm still groping ... (see photo)
I will be very grateful for your advice.
Regards and good health, Martin
Czech Republic
Martin Hudek - 返信
can't seem to find where to get a replacement spring. can you help?
Linda Monnes - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 31
今までの合計 948
