はじめに
The proximity sensor, or eye sensor, is used to tell the Panasonic Lumix DMC-GX85 when to activate the viewfinder when you put your eye up to it. If this is not happening when you hold the camera up to your eye, you may need to replace this sensor.
必要な工具と部品
Remove the 4.5mm black Phillips #0 screw under the viewfinder.
Gently pull the viewfinder cover from the camera.
Hold the viewfinder with the ribbon cables facing up and towards you.
Remove the black 4.5mm screw Phillips screw from the bottom of the viewfinder.
もう少しです!
終わりに
