はじめに
Do you need to replace the screen of your Panasonic Lumix DMC-GX85? Follow this guide to replace it! All you need is a Phillips head screwdriver and a plastic pry tool. As always, be careful when working on sensitive electronics, as screens are very fragile.
必要な工具と部品
Turn the camera so that the shutter side faces the ground and the lens faces you.
Orient the camera so the lens is facing the ground.
Using the gap created behind the screen at the bottom, stick the iFixit opening tool inside the gap and gently open the gap.
Work the tool evenly around the back of the display to evenly separate the two pieces. Once the back cover is separated enough, remove it by hand.
3 の人々がこのガイドを完成させました。
3 件のコメント
Thank you very much!
Thanks for the guide. From step 7, how do I further dismantle the screen. I bought a replacement screen, but its in a simpler form
