メインコンテンツにスキップ
Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Battery: 手順 1、 1の画像 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 2、 2の画像 1 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 2、 2の画像 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 手順 3、 3の画像 1 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 手順 3、 3の画像 2 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: 手順 3、 3の画像 3
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
  4. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 4、 3の画像 1 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 4、 3の画像 2 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 4、 3の画像 3
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
  5. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 5、 1の画像 1
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
  6. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 6、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
  7. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 7、 1の画像 1
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
  8. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 8、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
  9. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: 手順 9、 1の画像 1
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
  10. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: 手順 10、 2の画像 1 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: 手順 10、 2の画像 2
    • Push on the back panel buttons from the frontside of the back cover.
    • There might be some adhesives holding the back panel buttons to the cover. Extra force may be necessary.
終わりに
作成者
3人の作成者と共同で作成されました。
Kingsley East
メンバー登録日: 10/30/16
462 ポイント
4のガイドは作成済み
チーム
Baylor, Team 5-9, Williams Fall 2016 Baylor, Team 5-9, Williams Fall 2016人のメンバー
BU-WILLIAMS-F16S5G9
3 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 605
