メインコンテンツにスキップ
Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement, Mainboard: 手順 1、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement, Mainboard: 手順 1、 2の画像 2
    • Unlock and open the battery compartment on the bottom of the camera.
    • Remove both the battery and SD card.
  2. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 2、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 2、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 2、 3の画像 3
    • Remove the four indicated 3.0mm long black screws from the bottom of the camera and the viewfinder housing using a PH0 Phillips screwdriver.
    • There are four screws on the bottom of the camera. Only remove the two nearest to the screen.
  3. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 3、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 3、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 3、 3の画像 3
    • Remove the four indicated 6.0mm long black screws using a PH0 Phillips screwdriver.
    • Three of the screws are located on the sides of the chassis and one is directly underneath the battery compartment lid.
  4. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 4、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 4、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 4、 3の画像 3
    • Remove the viewfinder eye cup by pulling up and out from the bottom to separate the locking clips from the camera.
    • Do not flex the eye cup too aggressively as it may lose its shape.
    • Remove the two indicated silver 3.5mm long screws adjacent to the viewfinder screen using a PH0 Phillips screwdriver.
  5. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 5、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 5、 2の画像 2
    • Use an iFixit opening tool (or similarly long and thin object) to insert into the gap between the two camera halves and pry the camera apart from the top.
  6. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 6、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 6、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 6、 3の画像 3
    • Remove the two indicated ribbon cables before separating the two halves of the camera.
    • Using a flat object, pry open the black tabs above the ribbon cable connectors by gently pulling away from the motherboard.
    • An opening pick is recommended, but any equally small and flat object will work.
    • Ribbon cables are fragile, so put as little stress on them as possible.
  7. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 7、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 7、 2の画像 2
    • Remove the 4 indicated flex cables from top of mainboard
    • Remove the indicated small flex cable from top of mainboard.
    • The small flex cable does not have a lock: simply pull to disconnect it.
  8. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 8、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 8、 2の画像 2
    • Remove the 3 indicated flex cables from the bottom of the mainboard.
  9. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 9、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 9、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 9、 3の画像 3
    • Remove the 4 indicated red 3.0mm long screws from the corners of mainboard using a Phillips PH0 screwdriver.
    • With the eyepiece facing away from you, pull up on the main PCB from the left side and then pull it away from the chassis.
    • There is a plastic locking tab on the bottom of the camera that holds the mainboard PCB.
    • A replacement mainboard can be purchased from AliExpress here
  10. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement, Flash Capacitor/Fuse: 手順 10、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement, Flash Capacitor/Fuse: 手順 10、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement, Flash Capacitor/Fuse: 手順 10、 3の画像 3
    • Use a PH0 Phillips screwdriver to remove the 3 indicated red 3.0mm screws from heat sink shield, then remove the heat sink.
  11. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 11、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 11、 2の画像 2
    • Use a PH0 Phillips screwdriver to remove the two indicated black 6.0mm long screws from the top of the camera, underneath the flash mechanism.
    • Remove the indicated black 4.0mm long screw from the top of the camera
  12. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 12、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 12、 2の画像 2
    • Remove the three indicated silver 5.0mm long screws from the back of the camera and the right side using a Phillips PH0 screwdriver.
    • The two screws on the back require a very thin screwdriver as they are only accessible through the holes on the back shield.
  13. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 13、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 13、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 13、 3の画像 3
    • Remove the front grip from the camera by pulling it forward and out.
  14. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 14、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 14、 2の画像 2
    • Remove the indicated black 4.0mm long screw from the side under the front cover using a Phillips PH0 screwdriver.
  15. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 15、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 15、 2の画像 2
    • Remove the indicated silver 5.0mm long screw from under the front cover using a Phillips PH0 screwdriver.
  16. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 16、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 16、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 16、 3の画像 3
    • Lift the top unit away, separating it from the rest of the unit.
  17. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 17、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 17、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 17、 3の画像 3
    • Pull the top panel away from the rest of the camera to reveal the flash wire and plastic cover.
    • Use a spudger (or other small prying tool) to release the locking tab on the plastic cover.
    • Pull the flash wire out under the plastic capacitor PCB cover. At the same time lift the cover away.
  18. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 18、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 18、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 18、 3の画像 3
    • Remove the two indicated red 3.0mm long screws using a Phillips PH0 screwdriver.
    • Lift away the flash PCB.
  19. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 19、 3の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 19、 3の画像 2 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 19、 3の画像 3
    • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Determine if the capacitor or the fuse has failed. Using a Capacitance meter measure the capacitor, it should report a value of 130µF.
    • If the capacitor value reported is close, then use a voltmeter with continuity testing to probe the fuse. If there is no continuity, then the fuse is broken.
    • If the capacitor is the failure point, go to step 20 and stop there. Otherwise, if it is the fuse, skip to step 21.
  20. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 20、 1の画像 1
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    • Heat and remove the indicated solder on the two capacitor contact points.
    • Solder wick or a solder pump is recommended for removing solder.
    • Pull the flash capacitor away from the PCB.
  21. Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 21、 2の画像 1 Panasonic Lumix DMC-G7 Flash Capacitor/Fuse Replacement: 手順 21、 2の画像 2
    この手順で使用する道具:
    • The flash fuse is very close to the capacitor and plastic battery connector. Be careful not to touch them.
    • Remove the solder on one side of the fuse.
    • Heat the solder on other side and pull the fuse away.
    • Use tweezers or a similar tool to remove the fuse.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Alden Chu
メンバー登録日: 04/03/19
439 ポイント
2のガイドは作成済み
チーム
6件のガイドコメント
My G7 can’t turn on anymore. I tried to connect a DMW-AC8 Adaptateur secteur but after that, it never works again.
So I think it’s the fuse ? If it’s that how can I buy a new fuse ?
Matthieu Rousseau - 返信
Apologies for the delay, I’m one of the students who worked on this guide.
Unfortunately I believe your problem is likely something else. This guide relates specifically to the flash subsystem, so if the fuse or capacitor mentioned here were the problem I believe the device would still power on (though the flash wouldn’t work).
Alan Gardner -
Hi i have the same issue than the first coment
My camera dont turn on and isnt the motherboard, i know because i buy a replacement and didnt work either.
So you have some idea about what it is?
Excuse my english.
Aaron Gonzalez Montiel - 返信
I have a G7 that would not turn on, after replacing the Capacitor with one from another broken camera that I had laying around, was able to get it to turn on 2 or 3 times and while it was turned on it worked great.
The other capacitor had a smaller uF Rating (84 vs 130 in the original)
After leaving it turned of for a bit it would not turn on again.
I then opened it up again, discharged the capacitor and same thing happened, it worked again for a few times and as before stopped working.
Not sure if there is something with the resistance of the other capacitor that is different than the original. For now I ordered one that is a similar model but also smaller size, maybe that will help.
Dominik Bessler - 返信
It's pretty obvious from my experience that this fuse is not only for the flash subsystem cause it is in line with the V+ connector from the battery, and all the power needs to go through this fuse, or the V+ must also connct to the pcb on the other side of the board to provide the main power..
But, as far as i can see, that's not the case cause there is a IC there and no connections to the battery connectors, and no pins of the battery connector come through the board on the other side, so the chance that this is a three layered board is very slim as well.
i think that if you try to power on the camera without this fuse, it will refuse to go on.
marcurios - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 23
今までの合計 1,959
