メインコンテンツにスキップ
Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 手順 1、 3の画像 1 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 手順 1、 3の画像 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 手順 1、 3の画像 3
    • Remove the four 4.6mm J000 Phillips screws from the sides and two 3.2mm J000 Phillips screws along the bottom.
  2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 2、 3の画像 1 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 2、 3の画像 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 2、 3の画像 3
    • Remove the two 3.2mm J000 Phillips screws located on the bottom edge of the viewfinder cover.
    • Carefully remove the viewfinder cover.
    • Remove the two 4.4mm J000 Phillips screws located near the top edge of the viewfinder.
  3. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 3、 3の画像 1 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 3、 3の画像 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 3、 3の画像 3
    • Slide the Wide Plastic Opening Tool upwards along the underside of the rear casing.
    • Be careful not to disconnect the filament connections. Reinserting them can be difficult.
    • Slowly lower the casing into the position shown.
  4. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 4、 2の画像 1 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 4、 2の画像 2
    • Use the Screwdriver J000 Phillips Head to remove the screw located at the lower-left corner of the face of the viewfinder glass.
    • Carefully lift the L-shaped clicker underneath the previously removed screw.
  5. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 5、 2の画像 1 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 手順 5、 2の画像 2
    • Slide the faulty diopter adjustment dial off the rod.
    • Replace the diopter dial with a 1-cm wheel.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Gabriel Gonzalez Jr
メンバー登録日: 02/14/17
325 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-3, Kass Spring 2017 USF Tampa, Team 1-3, Kass Spring 2017人のメンバー
USFT-KASS-S17S1G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 1,060
