はじめに
This guide will show you how to almost completely strip down your device. Because of this, it may take a fair bit of time if you have never done a disassembly before. If you are looking for a guide to access the lenses themselves, this guide will not show that. However, it is possible if you have the patience to disassemble the lens casing.
ツール
パーツ
パーツは指定されていません。
Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
Unscrew the silver 2mm screw from the protection panel.
Unscrew the three black 8mm screws from the protection panel.
Remove the protection panel entirely.
