メインコンテンツにスキップ
Panasonic Lumix DMC-FX37 LCD Screen Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-FX37 LCD Screen Replacement, Panasonic Lumix DMC-FX37 Disassembly: 手順 1、 2の画像 1 Panasonic Lumix DMC-FX37 LCD Screen Replacement, Panasonic Lumix DMC-FX37 Disassembly: 手順 1、 2の画像 2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 LCD Screen Replacement: 手順 2、 2の画像 1 Panasonic Lumix DMC-FX37 LCD Screen Replacement: 手順 2、 2の画像 2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 LCD Screen Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-FX37 LCD Screen Replacement: 手順 3、 2の画像 2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 LCD Screen Replacement: 手順 4、 3の画像 1 Panasonic Lumix DMC-FX37 LCD Screen Replacement: 手順 4、 3の画像 2 Panasonic Lumix DMC-FX37 LCD Screen Replacement: 手順 4、 3の画像 3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 LCD Screen Replacement: 手順 5、 1の画像 1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
  6. Panasonic Lumix DMC-FX37 LCD Screen Replacement, LCD Screen: 手順 6、 1の画像 1
    • Use a plastic opening tool to pry off the LCD screen.
    • There is a small amount of adhesive lining the inside edges of the LCD screen. If you are having trouble prying off the screen, apply a small amount of heat to the front of the screen to melt the adhesive.
終わりに
作成者
3人の作成者と共同で作成されました。
Ben DuBose
メンバー登録日: 01/30/18
327 ポイント
3のガイドは作成済み
チーム
Baylor, Team S2-G3, Johnson Spring 2018 Baylor, Team S2-G3, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S2G3
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 351
