Push the memory card in and let go.
The memory card will pop out slightly.
Pull out the memory card.
Unscrew the small screws on the sides of the camera.
The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
Be careful not to damage the cylindrical capacitor on the circuit board under the top cover.
Use the spudger to lift up the back logic board.
Using your fingers, gently wiggle and pull off the back motherboard.
You will hear a click when you lift it up.
Use the spudger to lift the upper tab from the main housing.
Gently lift the lower tab from the main body by prying it with your finger.
Gently pull off the plastic motherboard housing sideways.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
