この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Directions are given as if you were holding the camera to take a picture.
必要な工具と部品
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
Use this screwdriver for all screws in the device.
ある他の人がこのガイドを完成しました。
