メインコンテンツにスキップ
Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement
必要な工具と部品
  1. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Battery: 手順 1、 1の画像 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 2、 1の画像 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 3、 1の画像 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Rear Casing: 手順 4、 1の画像 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 5、 1の画像 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 6、 2の画像 1 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 6、 2の画像 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 7、 1の画像 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 8、 1の画像 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 9、 2の画像 1 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 9、 2の画像 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, LCD Screen: 手順 10、 1の画像 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 11、 1の画像 1
    • Gently tug the thicker ribbon to remove it from its housing.
    Not sure i the author forgot to add this, but the black part of this connector is locking mechanism for the ribbon. Lifting it will help.
    Michal Andres - 返信
  12. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: 手順 12、 2の画像 1 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: 手順 12、 2の画像 2
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  13. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 13、 1の画像 1
    • Remove the two 3mm screws.
  14. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 14、 2の画像 1 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 14、 2の画像 2
    • Pry bars back gently as shown.
    • Fingers can be used but tool is shown for clarity.
  15. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 15、 2の画像 1 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 15、 2の画像 2
    • After, releasing all the components, gently remove the flash assembly from the casing.
  16. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 16、 1の画像 1
    • Remove the 1.2 mm screw from the settings wheel.
  17. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 手順 17、 1の画像 1
    • Replace buttons.
    • Replace the "On/ Off" button with the prongs facing away from the flash.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew
メンバー登録日: 10/11/10
396 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S9G22
4 メンバー
8のガイドは作成済み
コメント 1 件
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
Ricardo Britto - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 5,054
