必要な工具と部品
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
Gently tug the thicker ribbon to remove it from its housing.
Not sure i the author forgot to add this, but the black part of this connector is locking mechanism for the ribbon. Lifting it will help.
Carefully remove the upper assembly, which houses the buttons and the flash battery.
2 の人々がこのガイドを完成させました。
コメント 1 件
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
