この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will be useful for anyone who wants to replace a broken or damaged lens assembly.
必要な工具と部品
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
5 の人々がこのガイドを完成させました。
