メインコンテンツにスキップ
はじめに
Replacing the zoom is necessary if the assembly is damaged. It can also be useful to clean the assembly if grit gets through the initial lens rings. After the screen is removed there are two more parts that come out to access the assembly. It is easy to remove the ribbon cables attached to the assembly and remove it from there.
  1. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, Back Case: 手順 1、 3の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, Back Case: 手順 1、 3の画像 2 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, Back Case: 手順 1、 3の画像 3
    • Remove 5 screws attached to the back case using a 00 Phillips head screwdriver.
  2. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 2、 1の画像 1
    • Using your hands and a pry tool, lever the back case off.
  3. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 3、 2の画像 2
    • Remove the back case.
  4. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, Front Case: 手順 4、 3の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, Front Case: 手順 4、 3の画像 2 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, Front Case: 手順 4、 3の画像 3
    • Remove four screws on the front case using a 00 Phillips head screwdriver. Two will be on the side with the camera strap, one on the bottom, and one on the side opposing the camera strap. They will be in pairs, one screw holding the front case and one screw holding the back case.
  5. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 5、 1の画像 1
    • Using a plastic opening tool and your hands, pull the front case loose from the camera.
  6. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 6、 2の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 6、 2の画像 2
    • Remove the front case from the camera.
  7. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, LCD Screen: 手順 7、 3の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, LCD Screen: 手順 7、 3の画像 2 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, LCD Screen: 手順 7、 3の画像 3
    • Using a 00 Phillips head screwdriver, remove a screw from the top right corner of the screen.
    • Lift the screen, being careful not to tear the ribbon cables on the right side.
  8. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 8、 2の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 8、 2の画像 2
    • Access the ribbon cables by removing the green button receiver panel using a plastic opening tool. There is a white panel beneath. Carefully remove this using a plastic opening tool. The white panel may require some elbow grease to get it off, and the panel may make a snapping sound as it comes off.
  9. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 9、 2の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 9、 2の画像 2
    • One of the ribbon cables will be housed behind the screen and the other will be under the panels. Gently pull each free from the housing and remove the screen.
  10. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, Lens Assembly: 手順 10、 2の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement, Lens Assembly: 手順 10、 2の画像 2
    • Under the screen is a silver panel. Remove three screws using a 00 philips screwdriver and take the plate off.
  11. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 11、 1の画像 1
    • Remove the silver panel with the buttons and flash battery from the top of the camera. The silver tripod socket may fall out. Do not be alarmed and don't put it back in.
  12. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 12、 2の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 12、 2の画像 2
    • Use the pry tool to lift the latches holding the ribbon cables in place. Gently tug on them, careful not to break them. The top ribbon cable will take more effort.
  13. Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 13、 2の画像 1 Panasonic Lumix DMC-FH25 Page Lens Assembly Replacement: 手順 13、 2の画像 2
    • Gently remove the lens assembly. It should slide out cleanly.
終わりに
2 の人々がこのガイドを完成させました。
Janice Weldon
メンバー登録日: 2017年03月07日
591 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G6, Isaacson Spring 2017 UMass Dartmouth, Team S6-G6, Isaacson Spring 2017人のメンバー
UMASSD-ISAACSON-S17S6G6
3 メンバー
10のガイドは作成済み
コメント 1 件
Hi I disassemble my câmera lens but I don't know How to reassamble It again,can you Help me? can I send you Fotos?
henry vargas pineda - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 504
