メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If your screen becomes damaged or broken it may need replacement. Removing the screen is an easy task involving the removal of a few screws and two cables. It is also necessary to remove the screen in order to access several parts beneath, such as the flash battery and lens assembly. Be careful not to tear the ribbon cables when the first screw on the screen is removed.
パーツ
パーツは指定されていません。
  1. Remove 5 screws attached to the back case using a 00 Phillips head screwdriver. Remove 5 screws attached to the back case using a 00 Phillips head screwdriver. Remove 5 screws attached to the back case using a 00 Phillips head screwdriver.
    • Remove 5 screws attached to the back case using a 00 Phillips head screwdriver.
  2. Using your hands and a pry tool, lever the back case off.
    • Using your hands and a pry tool, lever the back case off.
  3. Remove the back case. Remove the back case.
    • Remove the back case.
  4. Using a 00 Phillips head screwdriver, remove a screw from the top right corner of the screen. Lift the screen, being careful not to tear the ribbon cables on the right side. Lift the screen, being careful not to tear the ribbon cables on the right side.
    • Using a 00 Phillips head screwdriver, remove a screw from the top right corner of the screen.
    • Lift the screen, being careful not to tear the ribbon cables on the right side.
  5. Access the ribbon cables by removing the green button receiver panel using a plastic opening tool. There is a white panel beneath. Carefully remove this using a plastic opening tool. The white panel may require some elbow grease to get it off, and the panel may make a snapping sound as it comes off. Access the ribbon cables by removing the green button receiver panel using a plastic opening tool. There is a white panel beneath. Carefully remove this using a plastic opening tool. The white panel may require some elbow grease to get it off, and the panel may make a snapping sound as it comes off.
    • Access the ribbon cables by removing the green button receiver panel using a plastic opening tool. There is a white panel beneath. Carefully remove this using a plastic opening tool. The white panel may require some elbow grease to get it off, and the panel may make a snapping sound as it comes off.
  6. One of the ribbon cables will be housed behind the screen and the other will be under the panels. Gently pull each free from the housing and remove the screen. One of the ribbon cables will be housed behind the screen and the other will be under the panels. Gently pull each free from the housing and remove the screen.
    • One of the ribbon cables will be housed behind the screen and the other will be under the panels. Gently pull each free from the housing and remove the screen.
終わりに
2 の人々がこのガイドを完成させました。
Janice Weldon
メンバー登録日: 2017年03月07日
591 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G6, Isaacson Spring 2017 UMass Dartmouth, Team S6-G6, Isaacson Spring 2017人のメンバー
UMASSD-ISAACSON-S17S6G6
3 メンバー
10のガイドは作成済み
コメント1件
it has been quite easy tank you for sharing your help serge jobin
Serge Jobin - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 157
