メインコンテンツにスキップ
Panasonic Lumix DMC-FH20 Lens Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-FH20 Lens Replacement, Lens: 手順 1、 3の画像 1 Panasonic Lumix DMC-FH20 Lens Replacement, Lens: 手順 1、 3の画像 2 Panasonic Lumix DMC-FH20 Lens Replacement, Lens: 手順 1、 3の画像 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 Lens Replacement: 手順 2、 2の画像 1 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 2、 2の画像 2
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 Lens Replacement: 手順 3、 2の画像 1 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 3、 2の画像 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 Lens Replacement: 手順 4、 2の画像 1 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 4、 2の画像 2
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 Lens Replacement: 手順 5、 3の画像 1 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 5、 3の画像 2 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 5、 3の画像 3
    • Unscrew one screw (Phillips #000 head)
    • Remove the screen. You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
  6. Panasonic Lumix DMC-FH20 Lens Replacement: 手順 6、 3の画像 1 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 6、 3の画像 2 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 6、 3の画像 3
    • Remove the grey panel.
    • You will need to unscrew three screws (Phillips #000 head) in order to remove the panel.
  7. Panasonic Lumix DMC-FH20 Lens Replacement: 手順 7、 3の画像 1 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 7、 3の画像 2 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 7、 3の画像 3
    • Pop the two thin black pieces of plastic upwards with the opening tool to unlock the plastic film ribbons.
    • Once unlocked, you will need to unscrew six more screws (Phillips #000 head) to completely detach the lens from the rest of the camera.
  8. Panasonic Lumix DMC-FH20 Lens Replacement: 手順 8、 2の画像 1 Panasonic Lumix DMC-FH20 Lens Replacement: 手順 8、 2の画像 2
    • Remove the lens from the camera carefully. You can do this simply by grabbing it with your fingers and pulling out gently.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Arianna Boushell
メンバー登録日: 01/24/17
653 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S10G7
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 26
今までの合計 1,288
