メインコンテンツにスキップ
Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement
必要な工具と部品
  1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 2、 1の画像 1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Back Case: 手順 3、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 4、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 5、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 6、 2の画像 1 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 6、 2の画像 2
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 7、 2の画像 1 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 7、 2の画像 2
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 8、 1の画像 1
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: 手順 9、 2の画像 1 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: 手順 9、 2の画像 2
    • Use a spudger to lift the screen ZIF connector tab.
    • Use the back of the spudger to push the ribbon cable free.
  10. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 10、 3の画像 1 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 10、 3の画像 2 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 10、 3の画像 3
    • Use the screwdriver to remove the four 2.4 mm Phillips screws.
    • Lift up the LCD screen from the front case.
    • Potential for device damage: The wire is still connected to the board in the other side.
  11. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 11、 1の画像 1
    • Remove the LCD screen from its case.
  12. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 手順 12、 1の画像 1
    • Locate the wire connecting the LCD screen to the motherboard.
    • Use the soldering iron to desolder the wire.
    • Use the soldering iron to solder wires from new LCD screen to the circuit board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
11人の作成者と共同で作成されました。
Alex Penman
メンバー登録日: 01/28/11
463 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S7G35
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 3,042
