はじめに
Steps for removing the back half of the case and replacing it with a new one.
必要な工具と部品
Slide the lock switch to the right so that it is in the unlocked position.
Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
