メインコンテンツにスキップ
Panasonic LUMIX DMC-LX100 LCD Screen Replacement
必要な工具と部品
  1. Panasonic LUMIX DMC-LX100 LCD Screen Replacement, Battery: 手順 1、 3の画像 1 Panasonic LUMIX DMC-LX100 LCD Screen Replacement, Battery: 手順 1、 3の画像 2 Panasonic LUMIX DMC-LX100 LCD Screen Replacement, Battery: 手順 1、 3の画像 3
    • Looking at the bottom of the camera, slide the OPEN/LOCK switch to the left into the OPEN position.
    • The battery housing door should swing open.
  2. Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 2、 2の画像 1 Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 2、 2の画像 2
    • Flip the inside switch up to release the battery.
  3. Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 3、 1の画像 1
    • Grip the edge of the battery and pull it out.
    • Use a LUMIX Panasonic DMW-BLE9PP Battery Pack for replacement.
    How to take off the battery housing door? Is it necessary to take the front cover off in order to do it?
    Boser Hund - 返信
    Hello, how to take the battery housing door off on lx100? Is taking the front cover off necessary? The whole tutorial is great but the most common part that breaks often is not covered.
    Boser Hund - 返信
  4. Panasonic LUMIX DMC-LX100 LCD Screen Replacement, LCD Screen: 手順 4、 3の画像 1 Panasonic LUMIX DMC-LX100 LCD Screen Replacement, LCD Screen: 手順 4、 3の画像 2 Panasonic LUMIX DMC-LX100 LCD Screen Replacement, LCD Screen: 手順 4、 3の画像 3
    • Some of these screws may have adhesive to keep the camera from being taken apart so push hard with the screwdriver and turn slowly to avoid stripping screws.
    • Use a Phillips #000 screwdriver to remove the five 4.5 mm screws located on the bottom of the camera and the top one on the left side, with the lens facing you.
    • Use a Phillips #000 screwdriver to remove the two 3.5 mm screws, one below the lens and one on the left side.
    • Use a Phillips #000 screwdriver to remove the 7.1 mm screw from the right side of the camera.
    Only the screw below the lens was 3.5 mm. Both screws on the left side were 4.5 mm
    pinkerton.farm - 返信
    The screw on the lens and the screw nearest to it (beneath the tripod mount) do not need to be removed if you only want to remove the sensor to clean it.
    Stefan - 返信
  5. Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 5、 1の画像 1
    • The viewfinder in this picture is taken off of the camera to more easily see where the screw is located. It is not actually removed from the camera.
    • Use a Phillips #000 screwdriver to remove the 2.5 mm screw underneath the viewfinder.
    • Pull the black plastic piece off of the viewfinder.
    This was a 4.5 mm screw.
    pinkerton.farm - 返信
    To pull it off, pull the bottom side first. Removing this cover offers the advantage to clean the viewfinder glass.
    Stefan - 返信
    This screw has a coarser thread pitch than the others
    Ren Yuthok - 返信
  6. Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 6、 3の画像 1 Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 6、 3の画像 2 Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 6、 3の画像 3
    • Slide out the black plastic piece that acts as a placeholder for an attachable lens on the top of the camera.
    • Remove the small metal insert that rests beneath the black plastic piece by pulling outward, away from the lens side of the camera.
    • You may need a spudger or prying device to remove the metal piece by lifting the back end up.
  7. Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 7、 1の画像 1
    • Use a Phillips #000 screwdriver to remove all four of the 7.1mm screws that are under the metal piece.
  8. Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 8、 1の画像 1
    • There may be adhesive holding the back on, so pry carefully to not break any of the ribbon cables underneath.
    • Pry off the back of the camera using a spudger starting from the top right side of the LCD screen.
    The top right is stuck that i cannot pry off the back plate, is there a screw or some adhesive ?
    parentshyps - 返信
    there's a screw that mount the 4-way scroll wheel to the back plate, DO NOT try to pry off the back plate as shown in the photo by force.
    You should pry off the back plate with the scroll wheel, and then detach the flat cable on the camera.
    jenghanhsieh - 返信
    My device had a additional screw underneath the rubber piece. I had to remove the rubber piece partially and then I could remove the screw (silver one with a big, flat head). Now I could continue to remove the back. Also the 4-way scroll wheel and buttons are screwed to the back plate, so two screws this guide doesnt show.
    Rincewind - 返信
    Agree with the comments above. The screw pictured in Step 9 is behind the rubber thumb rest in step 8 and must be removed before the back can be taken off. Also, the buttons are attached to the back plate by a screw, so will come off with the back plate. They are attached to the motherboard with a ribbon cable that must be disconnected.
    Damon Schreiber - 返信
    I think this is the difference between the LX100 and the LX100S versions. I had the same challenges above.
    Trigg Bowlin - 返信
    I also had a screw under the rubber thumb pad. And the rubber thumb pad should not be completely removed as it was attached to the back plate via a small screw from the inside of the back of the camera.
    Looking at the back of the camera, only remove the left (thinner) side of the rubber thumb pad in order to get access to the hidden screw. This screw needs to be completely removed before prying the back off the camera.
    pinkerton.farm - 返信
    Im struggling to get it off where the Fn3 and Fn2 buttons are, any suggestions?
    ellie1 - 返信
    for the ZIF cable connectors, DO NOT LIFT ON THE WHITE PART. The ZIF connectors here have a black bar on the back that you left up on.
    Ren Yuthok - 返信
    again , screw behind thumbrest needs to be removed , certainly on the LX100 mk 1 variant , otherwise a really helpful article !
    swlewthwaite - 返信
  9. Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 9、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the 7.5mm screw on the top right of the back of the camera that holds the metal backing in place.
    I had to remove this screw in the previous step, otherwise I couldn't remove the back.
    Rincewind - 返信
    I agree with Rincewind. This screw was hidden under the thin part of the rubber thumb pad on the back of the camera and it needed to be removed in the previous step.
    pinkerton.farm - 返信
    same with me, please update this step, otherwise some users might strip the screw forcefully
    Kevin Darras - 返信
    It’s documented in the service manual that you have to remove this screw before you take off the back cover, It can be accessed by lifting the left side of the rubber thumb rest. There’s some adhesive beneath that rubber.
    Stefan - 返信
    Do you have a copy of service manual? I only need the part regarding tightening those torx screws. Thx
    Zao Pao -
    I also needed to remove this screw before opening the case. The navigation buttons across the right back-side of the camera, as well as the top row of buttons (fn2, fn3, etc) were all connected to the back panel. Be careful not to tear that ribbon cable when removing the back. Lift slowly. — On a side note. I could really use another one of theses screws (the one in this step) as mine has stripped after a few removals. Anyone know how or where I could get one of these?
    tdeckard2000 - 返信
  10. Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 10、 3の画像 1 Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 10、 3の画像 2 Panasonic LUMIX DMC-LX100 LCD Screen Replacement: 手順 10、 3の画像 3
    • Lift the LCD screen away from the device.
    • Pry off the silver metal backing with a spudger.
    • Pull out the ribbon cable that attaches the LCD screen to the motherboard.
    • If need be, use a plastic spudger to pry the ribbon cable out of its socket.
    • Remove the LCD screen.
    You have to lift the small black latch to open the socket for the ribbon cable. The cable then comes out easily.
    Stefan - 返信
    If you want to replace the broken battery door, you proceed until this step and then you are able to do it.
    Ferdinand Hami - 返信
    I pulled out the connector and try to push it back in and was too tight. It did not work, there is black bar on the backside that had to be clicked up from the back for release to put the lcd connector back in easier. This would prob be better to do before removing the connector to loosen it first. Camera is fixed and working now. Did not replace lcd but reconnected which fixed the grey pixelated screen.
    Jaime Escher - 返信
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Annie Borland
メンバー登録日: 01/11/16
236 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 70-4, Forte Winter 2016 Cal Poly, Team 70-4, Forte Winter 2016人のメンバー
CPSU-FORTE-W16S70G4
4 メンバー
9のガイドは作成済み
8 件のコメント
Fantastic guide, what a help. Follow the caution details about stripping screws. I found that a #00 screwdriver worked better in some places than the #000. The screw in step 9 holds onto the back of the cameras frame in step 8 on my camera, so you might have to peel back the rubber thumb grip to get at it before you start prying the back case off so you don't bend or break the case. Other than that if I had to do it again it probably would take less than 20 minutes.Iit took me about an hour after stripping a couple screws with my #000 and looking for another screwdriver. Also a spudger isn't necessary, I used a guitar pick and a tooth pick to accomplish the same thing.
gunsr4kids - 返信
Hello-Can you describe the reference ,part number,of the LCD to order one ?thanks
pouliquen - 返信
Same questions as pouliquen, where to find a new LCD and part number ? thanks for help :)
Nicolas Tozman - 返信
Brilliant guide! I had the same problem as gunsr4kids. The screw in step 9 was actually holding the frame in place. I had to lift up the thumb rubber on the left side (there is adhesive on the back) to reveal the screw. Don't pull the rubber to hard
Johannes Cramer - 返信
The part number is DC9301
Where can I get the screen replacement?
Yoel Reinoso - 返信
The part number in found is SYP0013 price: $107-$112 shipped.
Yoel Reinoso - 返信
You do need to remove the screw under the right thumb grip! I almost broke it if i didn’t peel back the rubber grip. Not sure why this step is after you remove the back of the camera, it should be before. Other than that, it’s a guide.
N Thanh - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 22
過去 30 日: 103
今までの合計 5,755
