メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide will demonstrate how to replace the stepper motor on your typewriter, step-by-step.
パーツ
パーツは指定されていません。
  1. Flip the typewriter to expose the bottom body panel. Be careful to not damage the top surface of the typewriter when you rest it upside-down.
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis. Remove the two 19 mm screws using a Phillips #2 screwdriver.
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Flip the plastic lever on the right side of the roller wheel to disengage the paper lock. Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Remove the roller wheel adjustment knobs by pulling firmly outward. Both black knobs must be removed in this step. Both black knobs must be removed in this step.
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends. Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. While both spring levers are depressed, lift up with both hands to remove the roller wheel. While both spring levers are depressed, lift up with both hands to remove the roller wheel.
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis. Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis. Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
  10. Do not remove the screws fully from the stepper motor. Just unscrew them enough to allow the stepper motor to come loose. Removing them all the way can cause damage to the motor. The stepper motor is located on the left when looking from the rear of the typewriter.  Rotate the typewriter so that the stepper motor is facing you.
    • Do not remove the screws fully from the stepper motor. Just unscrew them enough to allow the stepper motor to come loose. Removing them all the way can cause damage to the motor.
    • The stepper motor is located on the left when looking from the rear of the typewriter. Rotate the typewriter so that the stepper motor is facing you.
    • While loosening the screws, use your finger to brace the corresponding nuts found on the opposite side of the stepper motor mounting bracket.
    • Using a P1 screwdriver, unscrew the top right and bottom right integrated #3 screws from the back of the stepper motor.
  11. Remove the stepper motor by pulling it straight out.
    • Remove the stepper motor by pulling it straight out.
終わりに
To reassemble your device, follow these instructions in reverse order using a working stepper motor.
Lindsay Stratis
メンバー登録日: 2015年04月08日
491 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 17-1, Forte Spring 2015 Cal Poly, Team 17-1, Forte Spring 2015人のメンバー
CPSU-FORTE-S15S17G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 308
