メインコンテンツにスキップ
Panasonic KX-E603 Fuse Replacement
必要な工具と部品
  1. Panasonic KX-E603 Fuse Replacement, Case: 手順 1、 2の画像 1 Panasonic KX-E603 Fuse Replacement, Case: 手順 1、 2の画像 2
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Fuse Replacement: 手順 2、 1の画像 1
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Fuse Replacement: 手順 3、 1の画像 1
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Fuse Replacement: 手順 4、 2の画像 1 Panasonic KX-E603 Fuse Replacement: 手順 4、 2の画像 2
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Fuse Replacement: 手順 5、 2の画像 1 Panasonic KX-E603 Fuse Replacement: 手順 5、 2の画像 2
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Fuse Replacement: 手順 6、 3の画像 1 Panasonic KX-E603 Fuse Replacement: 手順 6、 3の画像 2 Panasonic KX-E603 Fuse Replacement: 手順 6、 3の画像 3
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Fuse Replacement: 手順 7、 2の画像 1 Panasonic KX-E603 Fuse Replacement: 手順 7、 2の画像 2
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Fuse Replacement: 手順 8、 2の画像 1 Panasonic KX-E603 Fuse Replacement: 手順 8、 2の画像 2
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Fuse Replacement: 手順 9、 3の画像 1 Panasonic KX-E603 Fuse Replacement: 手順 9、 3の画像 2 Panasonic KX-E603 Fuse Replacement: 手順 9、 3の画像 3
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
  10. Panasonic KX-E603 Fuse Replacement, Fuse: 手順 10、 1の画像 1
    • The capacitors can be a shock hazard, avoid touching them.
    • The fuse can be found very close to two large, blue capacitors near the rear of the typewriter.
  11. Panasonic KX-E603 Fuse Replacement: 手順 11、 1の画像 1
    • The fuse body is made from glass; be careful not to use too much force or it could break.
    • Firmly grasp the fuse between your fingers and pull upwards to remove it from its mount.
    • If the fuse is difficult to grasp with your hands, a spudger may be used instead.
終わりに
To reassemble your device, use the new fuse and follow these instructions in reverse order.
作成者
4人の作成者と共同で作成されました。
Lindsay Stratis
メンバー登録日: 04/08/15
491 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 17-1, Forte Spring 2015 Cal Poly, Team 17-1, Forte Spring 2015人のメンバー
CPSU-FORTE-S15S17G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 414
