メインコンテンツにスキップ
Panasonic ER-GN30-K Motor Replacement
必要な工具と部品
  1. Panasonic ER-GN30-K Motor Replacement, Motor: 手順 1、 1の画像 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: 手順 2、 1の画像 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: 手順 3、 1の画像 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: 手順 4、 1の画像 1
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: 手順 5、 1の画像 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: 手順 6、 1の画像 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: 手順 7、 2の画像 1 Panasonic ER-GN30-K Motor Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: 手順 8、 1の画像 1
    • Remove the motor from the case by sliding the cover off of it.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Corey Tappan
メンバー登録日: 08/27/15
209 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 15-3, Blackwell Fall 2015 USF Tampa, Team 15-3, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S15G3
4 メンバー
10のガイドは作成済み
2 件のコメント
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - 返信
Thanks for such a detailed step by step to disassemble. It appears that the motor is not functioning: LD-050FF-2043V motor. But I was not able to find a replacement on the internet. Any suggestions?
David Freedman - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 27
過去 30 日: 55
今までの合計 3,934
