メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Panasonic EB-GD88 Camera Replacement
必要な工具と部品
  1. Panasonic EB-GD88 Camera Replacement, Prerequisite Guide for Camera, Screen Assembly: 手順 1、 3の画像 1 Panasonic EB-GD88 Camera Replacement, Prerequisite Guide for Camera, Screen Assembly: 手順 1、 3の画像 2 Panasonic EB-GD88 Camera Replacement, Prerequisite Guide for Camera, Screen Assembly: 手順 1、 3の画像 3
    この手順で使用する道具:
    • Flip cellphone open.
    • Out of the iFixit tool kit remove the black plastic opening tool, curved tweezers, and 54 bit driver kit.
    FixBotに聞いてみる
  2. Panasonic EB-GD88 Camera Replacement: 手順 2、 1の画像 1
    • Remove 4 rubber covers on the corners of the cellphone screen by prying them off with flat end of nylon spudger.
    • The rubber covers are glued on, but they should pop off easily.
    • These rubber covers may or may not be present.
    FixBotに聞いてみる
  3. Panasonic EB-GD88 Camera Replacement: 手順 3、 3の画像 1 Panasonic EB-GD88 Camera Replacement: 手順 3、 3の画像 2 Panasonic EB-GD88 Camera Replacement: 手順 3、 3の画像 3
    • Using a Y0 tri-wing screwdriver, found in the 54 bit driver kit, remove the two screws above the screen. Twist the screws counterclockwise to remove.
    • These two screws are blueish
    • Using a Y0 tri-wing screwdriver, remove the two screws below the screen. Twist the screws counterclockwise to remove.
    • These two screws are silver and longer than the bluish.
    FixBotに聞いてみる
  4. Panasonic EB-GD88 Camera Replacement: 手順 4、 3の画像 1 Panasonic EB-GD88 Camera Replacement: 手順 4、 3の画像 2 Panasonic EB-GD88 Camera Replacement: 手順 4、 3の画像 3
    • Carefully pry front cover of cellphone off with flat end of nylon spudger.
    FixBotに聞いてみる
  5. Panasonic EB-GD88 Camera Replacement: 手順 5、 3の画像 1 Panasonic EB-GD88 Camera Replacement: 手順 5、 3の画像 2 Panasonic EB-GD88 Camera Replacement: 手順 5、 3の画像 3
    • Insert nylon spudger or curved tweezers into small gap between the phone's outer gray casing and the inner gray plastic compartment (which holds the green circuit board and screen together). This gap is indicated by red arrows.
    • Use the tools as leverage to pop out inner gray compartment unit (screen, gray plastic, and circuit board) away from the phones outer casing .
    • Place nylon spudger and tweezers in the space between the outer phone casing and the inner gray compartment.
    FixBotに聞いてみる
  6. Panasonic EB-GD88 Camera Replacement, Camera: 手順 6、 2の画像 1 Panasonic EB-GD88 Camera Replacement, Camera: 手順 6、 2の画像 2
    • Use fingers to pop up gold piece (below the antenna).
    FixBotに聞いてみる
  7. Panasonic EB-GD88 Camera Replacement: 手順 7、 1の画像 1
    • Flip up circuit board and screen.
    FixBotに聞いてみる
  8. Panasonic EB-GD88 Camera Replacement: 手順 8、 1の画像 1
    • Pull off gray cover with black circular camera piece at the bottom of the screen.
    FixBotに聞いてみる
  9. Panasonic EB-GD88 Camera Replacement: 手順 9、 1の画像 1
    • Use fingers to slide camera out of slot.
    FixBotに聞いてみる
終わりに
作成者
2人の作成者と共同で作成されました。
Patricia Taggart
メンバー登録日: 02/19/16
1 ポイント
3のガイドは作成済み
チーム
Ohio State, Team 1-4, Garvin Spring 2016 Ohio State, Team 1-4, Garvin Spring 2016人のメンバー
OSU-GARVIN-S16S1G4
2 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 55
今までの合計 426
