このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
分解
この分解は修理ガイドでは ありません。 お持ちのPanasonic EB TX320ASWを修理する際は、iFixitの修理ガイドをご利用ください。
この手順は未翻訳です。 翻訳を手伝う。
To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
To remove battery push clip in; battery will pop out.
Using a Star 3.0 bit, remove 4 screws in battery compartment.
To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
To remove speaker cover, pull out silver plate.
After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
5人の作成者と共同で作成されました。
メンバー登録日: 10/04/11
10 ポイント
1ガイドが承認済み
バッジ: 3
UWSTOUT-ZHOU-F11S5G2
2 メンバー
1のガイドは作成済み
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 3,450
