メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Panasonic DVD-RV31 Player Disk Drive Replacement
必要な工具と部品
  1. Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Tray Cover: 手順 1、 1の画像 1
    • Eject the disk tray from the DVD player before removing power supply.
  2. Panasonic DVD-RV31 Player Disk Drive Replacement: 手順 2、 1の画像 1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Panasonic DVD-RV31 Player Disk Drive Replacement, Outer Case: 手順 3、 2の画像 1 Panasonic DVD-RV31 Player Disk Drive Replacement, Outer Case: 手順 3、 2の画像 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. Panasonic DVD-RV31 Player Disk Drive Replacement: 手順 4、 1の画像 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. Panasonic DVD-RV31 Player Disk Drive Replacement, Front Panel: 手順 5、 2の画像 1 Panasonic DVD-RV31 Player Disk Drive Replacement, Front Panel: 手順 5、 2の画像 2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  6. Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 手順 6、 3の画像 1 Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 手順 6、 3の画像 2 Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 手順 6、 3の画像 3
    • Locate the four screws securing the disk drive assembly. There are two on each side.
    • Use a narrow screwdriver to remove all four screws.
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
  7. Panasonic DVD-RV31 Player Disk Drive Replacement: 手順 7、 1の画像 1
    • Lift assembly by the front to pull metal bracket from the power board.
    • Pull up back end and lift drive out.
  8. Panasonic DVD-RV31 Player Disk Drive Replacement: 手順 8、 1の画像 1
    • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • Lift bracket off and reserve for re-assembly.
終わりに
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
William
メンバー登録日: 04/26/11
283 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S18G20
4 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 6,009
