メインコンテンツにスキップ
Panasonic DMC-FZ70 Viewfinder Replacement
必要な工具と部品
  1. Panasonic DMC-FZ70 Viewfinder Replacement, Back Panel: 手順 1、 2の画像 1 Panasonic DMC-FZ70 Viewfinder Replacement, Back Panel: 手順 1、 2の画像 2
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Viewfinder Replacement: 手順 2、 2の画像 1 Panasonic DMC-FZ70 Viewfinder Replacement: 手順 2、 2の画像 2
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Viewfinder Replacement: 手順 3、 2の画像 1 Panasonic DMC-FZ70 Viewfinder Replacement: 手順 3、 2の画像 2
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Viewfinder Replacement: 手順 4、 2の画像 1 Panasonic DMC-FZ70 Viewfinder Replacement: 手順 4、 2の画像 2
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Viewfinder Replacement: 手順 5、 1の画像 1
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Viewfinder Replacement: 手順 6、 1の画像 1
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Viewfinder Replacement: 手順 7、 3の画像 1 Panasonic DMC-FZ70 Viewfinder Replacement: 手順 7、 3の画像 2 Panasonic DMC-FZ70 Viewfinder Replacement: 手順 7、 3の画像 3
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 Viewfinder Replacement, Viewfinder: 手順 8、 2の画像 1 Panasonic DMC-FZ70 Viewfinder Replacement, Viewfinder: 手順 8、 2の画像 2
    • Using a plastic opening tool, flip up the black switch on the ZIF connector that attaches the viewfinder to the motherboard.
    • Once the connector has been opened, gently pull the cable from its slot.
  9. Panasonic DMC-FZ70 Viewfinder Replacement: 手順 9、 2の画像 1 Panasonic DMC-FZ70 Viewfinder Replacement: 手順 9、 2の画像 2
    • Holding the sides of the viewfinder, pull it out of the camera.
    • Removing the viewfinder requires a strong, yet steady pull.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Alberto Rodriguez
メンバー登録日: 01/24/17
531 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017人のメンバー
CPSU-MANESS-W17S21G3
6 メンバー
12のガイドは作成済み
コメント 1 件
Wow, this is very HELPFUL! I saved it with Zotero in case I need it one day. I'm simply looking for an eyepiece extender and/or rubber eyepiece combo. If you have a good source Photo Supply you'd recommend, please do so.
Mr. Phil - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,147
