はじめに
In this guide, you will take apart the back panel in order to reach the camera's viewfinder. A camera's viewfinder is used to line up your eye-view to the photo shot of the camera. No special requirements are necessary other than to exercise caution when taking out the ribbons. If the image you see through the viewfinder is significantly different than what is seen through the camera, or if you seen nothing but black, then you need to replace the part using this guide. Before you begin, make sure that the battery and SD card have been removed.
必要な工具と部品
Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
Using a plastic opening tool, flip up the black switch on the ZIF connector that attaches the viewfinder to the motherboard.
Once the connector has been opened, gently pull the cable from its slot.
ある他の人がこのガイドを完成しました。
