メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will help removed and replaced your damaged or old motherboard. If you have problems turning on your camera and you have checked your battery then you may need to follow this guide to replace the motherboard. Before you begin, make sure that the battery and SD card have been removed.
  1. All screws should be removed using a Phillips #0 screwdriver. Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there. Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Turn the camera upside down and  unscrew the three 5mm screws found on the bottom. Turn the camera upside down and  unscrew the three 5mm screws found on the bottom.
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. On the top of the camera  locate the two rails with a thin sheet of metal on the floor between them. With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Manta Driver Kit
    どんな修理にでも対応可能な112ビット
    Upgrade Your Toolbox
    Manta Driver Kit
  6. Proceed to remove the four 5mm Phillips screws that you just uncovered.
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  7. Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  8. Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard. Carefully pull the ribbon cables out of the slot once they have been released. Only the two indicated connectors need to be removed to separate the two halves of the camera.
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  9. Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
    • Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
  10. The five ribbon cables shown will need to be removed from the ZIF connectors. Using a plastic opening tool, unlock the cables by lifting  the black strip on the rectangular connection socket. Carefully pull each of the ribbon cables out of their sockets. The cable should slide out smoothly- any significant resistance might signal that the locking lever has not yet released the cable.
    • The five ribbon cables shown will need to be removed from the ZIF connectors. Using a plastic opening tool, unlock the cables by lifting the black strip on the rectangular connection socket.
    • Carefully pull each of the ribbon cables out of their sockets.
    • The cable should slide out smoothly- any significant resistance might signal that the locking lever has not yet released the cable.
  11. Once the screws and the ribbon cables have been removed, lift the mother board from its slot. Once the screws and the ribbon cables have been removed, lift the mother board from its slot.
    • Once the screws and the ribbon cables have been removed, lift the mother board from its slot.
終わりに
3 の人々がこのガイドを完成させました。
Emily Kuzmicky
メンバー登録日: 2017年01月24日
358 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017人のメンバー
CPSU-MANESS-W17S21G3
6 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 643
