All screws should be removed using a Phillips #0 screwdriver.
Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
Slowly pull on both side of the camera, until both halves begin to separate from each other.
Do not pull too hard, as both halves are held together with ZIF connector cables.
Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
Carefully pull the ribbon cables out of the slot once they have been released.
Only the two indicated connectors need to be removed to separate the two halves of the camera.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
