メインコンテンツにスキップ
Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement
必要な工具と部品
  1. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 1: 手順 1、 1の画像 1
    • Remove the battery and memory card from the device.
  2. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 2: 手順 2、 1の画像 1
    • Remove the single .5mm screw on the left side of the camera.
  3. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 3: 手順 3、 1の画像 1
    • Remove 4 (0.5mm) screws from the right side of the camera.
    • There are two screws at the top.
    • There are two screws at the bottom.
  4. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 4: 手順 4、 1の画像 1
    • Remove 5 screws from the base of the camera.
    • There are two (0.2mm) screws next to the battery compartment.
    • There are three (0.5mm) screws around the tripod base mount.
  5. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 手順 5、 1の画像 1
    • Slowly open the back cover away from the device
    • The wrist strap bar can easily be lost so now is a good time to remove it.
    • Use caution. The rear cover is attached to the Main PCB via cables. You will need to release these cables before removing the rear cover.
  6. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 手順 6、 2の画像 1 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 手順 6、 2の画像 2
    • Detach both ribbon cables using a spudger or other method.
    • Lift the black clip upward, unlocking the ribbon cable
    • Once the clip is in the up position you can slide the cable out. Release cable by pulling the cable out.
    • DO NOT pull on the Back case to release the cable.
  7. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 手順 7、 1の画像 1
    • Screw Arrangements
    • Make sure you organize your screws to make re-assembly easier.
  8. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 8: 手順 8、 1の画像 1
    • Remove the back casing from the camera.
  9. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 手順 9、 3の画像 1 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 手順 9、 3の画像 2 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 手順 9、 3の画像 3
    • Use a spudger or other tool to release the 3 clips between the LCD case and housing.
    • Note: when re-assembly all 3 clips need to be seated in the grooves as shown in the 2nd picture.
    • Lift LCD out as shown in 3rd picture
  10. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 手順 10、 1の画像 1
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Sales Cameraparts4you
メンバー登録日: 07/01/16
3,291 ポイント
21のガイドは作成済み
3件のガイドコメント
Very well presented and helpful - thank you.
It sems important to use the correct screwdriver and my impression is that the screws are JIS rather than Philips.
So far I have been unable to locate a replacement screen with back light (I assume the back light is connected by the narrower ribbon cable).
George Winspur - 返信
I  Like my Panasonic  DMC-TZ3  , paid 300 way back in 2007  and has flawlessly  perfect, till I Dropped it in the case  …
IT still take pictures,  store on Memory, etc  all functions work , and can down load to computer ..
BUT the Back LCD  I can barely see unless I put a LIGHT to it ….
SO I assume I screwed the Back Light,  … can anybody help ?
Gary Trembley - 返信
Hi…. the backlite cable might have come loose or damaged. I would disassembly the unit and re-insert the backlite cable to see if that does the trick.. Otherwise you would have to invest in a new Display ASSY or backlite. A used backlite or Display assy is not that expensive and easy to replace..
Sales Cameraparts4you - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 57
今までの合計 4,180
