はじめに
The most common part that can tear down and rip, and is easy to repair
必要な工具と部品
Make sure the machine is not under power and
remove the inner container
Remove the screw on the left side of the hinge of the lid (whith a philips 1 screwdrive)
After the screw is removed, you can move the lid (in open position) to the other side and slide it off the hinge (removing the lid completely)
Turn the complete machine upside down
Remove the four (PH1) screws from the four rubber stands.
When all screws are removed from the bottom side, the metal cover can be simply lifted up, and the motor is visible
With the help of the 8 mm wrench, remove the bolt from the black plastic gear wheel
lift the black gear wheel up and the belt drive can be replaced
ある他の人がこのガイドを完成しました。
