メインコンテンツにスキップ
PalmOne Zire 72 Control Pad Replacement
必要な工具と部品
  1. PalmOne Zire 72 Control Pad Replacement, Control Pad: 手順 1、 2の画像 1 PalmOne Zire 72 Control Pad Replacement, Control Pad: 手順 1、 2の画像 2
    • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
  2. PalmOne Zire 72 Control Pad Replacement: 手順 2、 1の画像 1
    • Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
    • If you peel the entire adhesive off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
    • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
  3. PalmOne Zire 72 Control Pad Replacement: 手順 3、 1の画像 1
    • Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
  4. PalmOne Zire 72 Control Pad Replacement: 手順 4、 1の画像 1
    • Use either end of the spudger to carefully pry off the camera lens mesh cover.
  5. PalmOne Zire 72 Control Pad Replacement: 手順 5、 1の画像 1
    • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
  6. PalmOne Zire 72 Control Pad Replacement: 手順 6、 2の画像 1 PalmOne Zire 72 Control Pad Replacement: 手順 6、 2の画像 2
    • Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
    • Gently remove the case to avoid damaging it. Do not try to force the case open.
    • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
  7. PalmOne Zire 72 Control Pad Replacement: 手順 7、 2の画像 1 PalmOne Zire 72 Control Pad Replacement: 手順 7、 2の画像 2
    • Remove the cover by lifting it from right to left.
    • This should be similar to the action of the opening of a book.
    • The brown film connecting the motherboard to the screen may tear if this is not done carefully.
  8. PalmOne Zire 72 Control Pad Replacement: 手順 8、 1の画像 1
    • Lift the control pad buttons off of the motherboard.
終わりに
作成者
5人の作成者と共同で作成されました。
Michelle Medina
メンバー登録日: 04/10/12
63 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 6-49, Amido Spring 2012 Cal Poly, Team 6-49, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S6G49
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 425
