メインコンテンツにスキップ
Palm v Outer Case Replacement
必要な工具と部品
  1. Palm v Outer Case Replacement, Outer Case: 手順 1、 1の画像 1
    • Lay device face down on surface.
  2. Palm v Outer Case Replacement: 手順 2、 2の画像 1 Palm v Outer Case Replacement: 手順 2、 2の画像 2
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Outer Case Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Outer Case Replacement: 手順 4、 1の画像 1
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Outer Case Replacement: 手順 5、 3の画像 1 Palm v Outer Case Replacement: 手順 5、 3の画像 2 Palm v Outer Case Replacement: 手順 5、 3の画像 3
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
ゴール
作成者
4人の作成者と共同で作成されました。
Anthony Platt
メンバー登録日: 02/09/10
66 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 13-25, Maness Winter 2010 Cal Poly, Team 13-25, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S13G25
4 メンバー
4のガイドは作成済み
コメント 1 件
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 1,602
