メインコンテンツにスキップ
Palm v LCD screen assembly replacement
必要な工具と部品
  1. Palm v LCD screen assembly replacement, Outer Case: 手順 1、 1の画像 1
    • Lay device face down on surface.
  2. Palm v LCD screen assembly replacement: 手順 2、 2の画像 1 Palm v LCD screen assembly replacement: 手順 2、 2の画像 2
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v LCD screen assembly replacement: 手順 3、 1の画像 1
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v LCD screen assembly replacement: 手順 4、 1の画像 1
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v LCD screen assembly replacement: 手順 5、 3の画像 1 Palm v LCD screen assembly replacement: 手順 5、 3の画像 2 Palm v LCD screen assembly replacement: 手順 5、 3の画像 3
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
  6. Palm v LCD screen assembly replacement, Screen: 手順 6、 2の画像 1 Palm v LCD screen assembly replacement, Screen: 手順 6、 2の画像 2
    • In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
    • To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
    • Once the clamp is up you can use the tweezers to gently detach the ribbon.
  7. Palm v LCD screen assembly replacement: 手順 7、 3の画像 1 Palm v LCD screen assembly replacement: 手順 7、 3の画像 2 Palm v LCD screen assembly replacement: 手順 7、 3の画像 3
    • Now you must flip up the adjacent clamp as well, using tweezers like before.
    • After the clamp is flipped you can gently remove the second ribbon with tweezers.
  8. Palm v LCD screen assembly replacement: 手順 8、 2の画像 1 Palm v LCD screen assembly replacement: 手順 8、 2の画像 2
    • Before removing the screen you must detach one more wire, the battery connector.
    • Using the tweezers, squeeze the connector attached to the wire and genlty pull.
    • Do not pull from the wire.
  9. Palm v LCD screen assembly replacement: 手順 9、 1の画像 1
    • Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
ゴール
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Adam Rianda
メンバー登録日: 01/19/10
22 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-25, Maness Winter 2010 Cal Poly, Team 13-25, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S13G25
4 メンバー
4のガイドは作成済み
コメント 1 件
Can the electroluminescent backlight panel be separated from the LCD? Then clip out the wires related to the LCD? Is that possible or are they fused?
Daniel Hargett - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 3,165
