はじめに
The purpose to this guide is to show how to properly replace the screen on a Palm V.
必要な工具と部品
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
Once the clamp is up you can use the tweezers to gently detach the ribbon.
ある他の人がこのガイドを完成しました。
コメント 1 件
Can the electroluminescent backlight panel be separated from the LCD? Then clip out the wires related to the LCD? Is that possible or are they fused?
