メインコンテンツにスキップ
Palm m500 LCD Screen Replacement
必要な工具と部品
  1. Palm m500 LCD Screen Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Palm m500 LCD Screen Replacement: 手順 2、 2の画像 1 Palm m500 LCD Screen Replacement: 手順 2、 2の画像 2
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. Palm m500 LCD Screen Replacement: 手順 3、 3の画像 1 Palm m500 LCD Screen Replacement: 手順 3、 3の画像 2 Palm m500 LCD Screen Replacement: 手順 3、 3の画像 3
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  4. Palm m500 LCD Screen Replacement, Battery: 手順 4、 3の画像 1 Palm m500 LCD Screen Replacement, Battery: 手順 4、 3の画像 2 Palm m500 LCD Screen Replacement, Battery: 手順 4、 3の画像 3
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
  5. Palm m500 LCD Screen Replacement, Motherboard: 手順 5、 3の画像 1 Palm m500 LCD Screen Replacement, Motherboard: 手順 5、 3の画像 2 Palm m500 LCD Screen Replacement, Motherboard: 手順 5、 3の画像 3
    • Use the plastic opening tool to pry the orange clamp away from the motherboard.
    • Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
    • Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
  6. Palm m500 LCD Screen Replacement, LCD Screen: 手順 6、 2の画像 1 Palm m500 LCD Screen Replacement, LCD Screen: 手順 6、 2の画像 2
    • Pull the LCD screen up from the bottom of the device using your forefinger.
    • The LCD screen will easily come away from the front panel.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Miles Johnson
メンバー登録日: 01/11/11
579 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 14-9, Forte Winter 2011 Cal Poly, Team 14-9, Forte Winter 2011人のメンバー
CPSU-FORTE-W11S14G9
6 メンバー
6のガイドは作成済み
コメント 1 件
The hardest part is getting the back plate off, I throttled my plastic spudger.
dpchoung - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 15
今までの合計 2,158
